Transmitter operating Strength
Old 03-15-2008, 02:55 PM
pipercub6
My Feedback: (16)
pipercub6's Avatar
Default Transmitter operating Strength
Hey Everybody,
This is not a BS question but a honest one. I recently received, by way of an excellent doctor, a pacemaker with a built in defibulator to keep my old heart working correctly. In the skads of paperwork I also had to read through it told about the many things that I have to be careful being around due to the frequencies it operates on and the location around anything with a strong magnetic field.
Just to be safe about it,
I am trying to find out the signal strength because I still intend to keep flying. I currently have both Hitec and Futaba radios, all either FM or PCM models. From what I understand a transmitter of 5 watts or greater held within 12 to 18 inches of my pacemaker could have an effect on it. I will read the paperwork again but if someone has the answer it would be greatly appreciated.
Thanks, Pipercub 6
Old 03-15-2008, 03:44 PM
DMcQuinn
My Feedback: (13)
Default RE: Transmitter operating Strength
Our R/C transmitters are about 1/4 watt or less. This is on 72 mHz. I don't have a 2.4 gHz system but I think their power output is similar.
Old 03-15-2008, 03:57 PM
glasrep
FCC regulations: Section 95.210 involving power regulations are frequency related. Please note 72-76 mhz section
Sec. 95.210 (R/C Rule 10) How much power may I use?
(a) Your R/C station transmitter power output must not exceed the
following value under any conditions:
Transmitter
power
Channel (carrier
power)
(watts)
27.255 MHz............................................... .. 25
26.995-27.195 MHz.......................................... 4
72-76 MHz............................................... ... 0.75
Hope this helps you, fly in good health!!
Kevin
