Radio questions
My Feedback: (10)
Radio questions
A couple quick (I hope) questions about transmitters, receivers, and crystals.
Will any fm radio, 27 or 75, work with any fm receiver of the same 27 or 75? ie: should brand 'A' tx work with brand 'B; rx if both are 75mhz using the same crystal?
are there special crystals for fm versus am? I have seen a few on ebay that do not specify am or fm.
I saw some crystals labeled 'am/fm', whats up with that?
and lastly, in the brand 'a' brand 'b' scenario above, can we use brand 'c' crystals?
I appreciate any answers, or links to answers. Trying to learn so I don't buy a bunch of stuff I don't need.
SC
RE: Radio questions
Without getting into a lot of technical details:
Some radios will not work with another manufacturer's crystals. It's best to stick with the same brand. Also, some radios will not work with other receivers. Make sure the RX is rated to work with the TX. AM will not work with FM. 27 will not work with 72, etc. Dual conversion/narrow band radios must use the same type of crystal. My advice - Buy a full radio set, complete with TX, RX, batteries, servos, crystals and switch harness. Don't get a slapped together eBay system unless you're SURE everything will work together.
Dr.1
Dr.1
My Feedback: (10)
RE: Radio questions
Well, that is sort of what I figured. The cheap side of me is drawn to the bits and pieces on ebay that are dirt cheap, but my inexperience with these tells me to stay away.
are there are sites that have a little more technical info for me to read up on?
Thanks for the info.
RE: Radio questions
ORIGINAL: kistner
RE: Radio questions
ORIGINAL: kistner
As to crystals (those in the receiver) there is no difference between AM and FM however, there is a difference in DC (dual conversion) and SC (single conversion) recievers. For DC, the main crystal (there are two in the receiver but only one you can change) is usually 11.7MHz different from the transmitted frequency while for SC (only one crystral in the receiver) the crystal is 455KHz different from the transmitted frequency. You cannot interchange transmitter and receiver crystals.
RE: Radio questions
ORIGINAL: Dr1Driver
Without getting into a lot of technical details: --------------------------------------------------------------------------------------------------------Don't get a slapped together eBay system unless you're SURE everything will work together.
Dr.1
Dr.1
You've obviously been doing some reading but "dual conversion, crystal, 27 and 72 MHz represent obsolete technologies when compared to 2.4GHz.
As you are starting out new why go with the old as I will guarantee you that they are LESS reliable than the 2.4 technology------though you will find a lot of sheer BS on the web that they are not.
When I started RC we were ALL on 26.995MHz.
The new is also VERY reasonably priced.
Your choice, simply additional input-------and unless you are interested in Radio Control history belay reading about dual and single conversion, PCM, PPM, FM etc.
My Feedback: (10)
RE: Radio questions
I follow you, but my wallet can't go there! over 200 for the 2.4 systems or under 50 for 'obsolete' but functional. These are still just toys for me. I did not spring for a lcd tv or a blueray player yet either; my car doesn't have cruise control; I build my own computers; etc. I guess I'm a little too cheap for new tech/high tech.
But I still appreciate the info
Thank you all
Thank you all
RE: Radio questions
ORIGINAL: kistner
Thank you all
Thank you all
