Zapped by a 9ZAP WC
My Feedback: (32)
Zapped by a 9ZAP WC
I traded my old 9zap for the new WC (Synth)version. I set up my new U CAN DO 3D with all Hitec digital servos and used my old reciever. This reciever had worked perfectly with the old transmitter. I got in two perfect flights with the new set up then I recharged the batteries and flew again as I set up for landing the airplane started acting strangely like I was taking radio hits, but not quite maybe more like a delayed response. I managed to go around and make another attempt as I approched the landing same thing happened and this time Igot zapped and rolled into the groung.
My Feedback: (31)
Zapped by a 9ZAP WC
Most likely the problem is the RX in use. Is it a Hitec RX? Some of them act like you have mixes of some sort activated. I have several that work fine and several that do not. I understand there are specification tolerances that can be outside what is needed for the Futaba synthesized module. I have a local radio guru test my RX's and change a .20 resistor to alleviate the unknown. If you use a standard module you will not have a problem.
