2.4Ghz & RF Noise?
Old 03-24-2008, 05:56 PM
mwunsworth
My Feedback: (13)
mwunsworth's Avatar
Default 2.4Ghz & RF Noise?
Been considering transitioning over to 2.4Ghz but does anyone know if the 2.4Ghz is affected by RF noise that typical 72Mhz systems react to from electronic ignition gas engines?
Old 03-24-2008, 06:30 PM
codimasta
My Feedback: (89)
Default RE: 2.4Ghz & RF Noise?
[8D]No problems...I am running a DL50 on my Giant Aeromaster...JR 9303/2.4....The throttle linkage is 4/40 wire with a metal clevis...not problems.
Go to : www.spektrumrc.com and read about Spektrum 2.4 ghz...the rf noise area is a lower frequency than 2.4
Hope this helps
Codimasta
AMA 11269
Old 03-24-2008, 07:15 PM
kwhite.6
Look in the gas engine section under fuji 43 rfi probs. Mrammo said it was worst with his 9303 2.4 than 72mhz.
Old 03-25-2008, 07:28 AM
Rodney
In most cases, rf generated by our systems are in a frequency range not often effecting 2.4GHz but not always. We had one case at our field where the electronic ignition system made a 2.4GHZ unit unflyable yet did not bother the 72 MHz units, not normal but it can happen. All frequencies can be effected by interference, especially any where sparking is involved as a spark (an electrical discharge across a gap between two conductors) usually contains components of all frequencies.
Old 03-25-2008, 09:20 AM
Four Stroker
Bingo Rodney;
There are ancient patents of spark gap microwave transmitters. If the wiring around the spark is accidentally tuned to 2.4 GHz, it is a jammer.
Old 03-25-2008, 10:17 AM
dirtybird
Of course its possible but very, very improbable on 2.4 ghz. Its not only possible but probable on 72 mhz
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
