Using a 6exhp for aiplanes
Can you use the 6exhp radio on airplanes? i have a chance to swap my 6exap for a 6exhp. i just recently started flying helis and this trade is very tempting, both radios are used but like new. If you can use the 6exhp on airplanes what functions dose it have and how do you activate the airplane functions? i was looking at the 6exhp manual and did not see anything that would subjests that you can use it with airplanes. Can some one clear this up for me?
RE: Using a 6exhp for aiplanes
Even if it doesn't have airplane programming, you can use it to fly airplanes using the basic functions on channels 1-4. It might not come with mixing for stuff like two aileron servos but you can use a y-harness for that.
There's a couple versions of the 6ex floating around, AFAIK the ones that are designated 6EXH and 6EXA only have software for helicopter and fixed wing respectively.
http://www.futabarc.com/radios/feature-compare.html note for 6exh it says ACRO PROGRAMMING: NO
