Meter question on older Futaba FG series...
OH
Hello, i have a older Futaba FG series radio, works very good, This radio has the large module in back that plugs in, i read somewhere that if you unplug this module the meter should still work, this does not, my brother has one also same thing... If someone could help that would be great, maybe let me know if yours is the same, thanks.. flyby50...
RE: Meter question on older Futaba FG series...
Easiest sure answer is to call or at least email Tony Stillman @ Radio South.
Numbers are here: http://www.radiosouthrc.com/
My Feedback: (27)
The meter is an indication of the battery voltage not the RF output. The resistor it measure a voltage drop accross is inside the module. Since part of the circuit is inside the module it will not give any indication without the module in the transmitter.
Pete
Pete
Actually it really is an ammeter[)], that is why it will give a different reading depending on whether the antenna is extended or not.
Pete
Pete
That meter, like a ticking clock in a puppy's bed, did little other than give you a needle to watch.
Not just Futaba's but ALL of them.
That is why post two suggested that the thread starter go to Tony Stillman for a reply.
OH
Thanks to all that helped, i did e-mail Tony and as soon as i hear something i'll post it , i feel better about my old radio, she's going in a plane soon You guys know your stuff !!! [sm=47_47.gif]
OH
One Wasp, thanks for letting me know about radio south, they just sent me an e-mail and said the radio will not work without the module- i'm sure someone from futaba told me that it should work, oh well we all make mistakes, thanks again[sm=thumbup.gif]
According to the instruction manual that came with those transmitters:
The "Square level meter indicates the transmitter output power and indirectly shows power supply voltage."
In other words, it's an ammeter that is showing the current flowing through the final output stage of the transmitter, and when the meter starts to go down, the battery pack voltage is going down. That's because voltage is the "push" that moves current. When current declines, it indicates that the voltage is declining.
