Futaba 6014 receiver heat issue
My Feedback: (243)
RE: Futaba 6014 receiver heat issue
ORIGINAL: superdave01
Makes me wonder if Futaba own this entire forum....... anything negative about Futaba gets deleted.
How many ways do they have to explain to impatient clods that Futaba is aware and looking into it?
I agree with some posts here and on the support forum…if it is 140 degrees inside the fuse, you have other problems that need addressing. But…naw…..let’s blame Futaba because, with my ability to have all these expensive toys, I’m doing everything right and I demand an answer right now!
I don’t care how hot it gets in Arizona, Death Valley or Timbuktu….it gets easily to 105-110 degrees here in central California. I guess we have sense enough to get ourselves and our models out of the sun when it’s hot!
ORIGINAL: pattratt
Update on my original post to Futaba Factory direct forum.
Looks like Futaba USA is unwilling to "BUG" Japan on this or they are unwilling to tell me the "WHAT or WHEN we might expect something regarding the heat issue. It doesn't take a month to at least determine if ther IS or IS NOT a problem and if there is at what temperature does it occur. I recoginize the solution could take some time but the recognition of a problem [if it exist] should take less than a day.
Futaba USA does not want to discuss the issue other than to tell me to be patient and "LOCK" the thread!!
I own my own business as a distributor of Manufactured Goods. If I treated my customers this way, I soon would not have any problems or CUSTOMERS!!!
I'm curious how much influence you have over the companies for which you act as a distribution point.
And while it may annoy a lot of people, they truly cannot tell you when Futaba will have a solution because the people in Japan have not told them. But when they (Bill & Krysta) tell people this they get accused of lying, denying, stonewalling, etc.
ORIGINAL: dick Hanson
High temps and electronics are nothing new go under the hood of a modern auto - on a summer day
you will find 160 I was repairing a Ford Explorer-with a damaged front left fender - what do you thinkl I found under the fender skirting -outside the engine compartment?
yep - a module - for the brakes.
I can't beleive Futaba did a setup which won't withstand the heat in fuselages .
Did they?
this kind of thing should never make it past basic design.if indeed it did
Did they?
Patrick
TX
If a products fails in the inviroment for which its intended to use in then its a flawed design...... I dont mean the ocassional lemon.
Many times a electronic componemt is available in several operating temperature ranges, Many times a heat related problem will be from lack of propery heatsinking certain parts, Ive seen where there simply was no heatsink compound, In that case that alone fixed it.
The question i wonder is how many cases of failure do we know of so far???
What we really need here is for Futaba in Japan to issue a statement of findings. Until then all we have is speculation.
And I too would like to know how many real life failures there are. I am not talking about failures under a heat gun or in an oven, but actual failures in a plane at the field. That seems to have gotten lost.
And to the same point I would like to know how many are NOT having issues despite operating in high heat areas. One thing that needs to be looked at is if there is anything that the failed installations have in common. And the same goes for installations where they are working fine.
#31
I think if people have been using their receivers a certain way for years with no heat
related issues but then get a new receiver and all of sudden they start to have issues
then that says a lot. And what it means is either there is a bad bunch of receivers out
there or the receivers were not tested properly or the fact that the new receivers tend to
be more heat sensitive was not properly disclosed.
#32
My Feedback: (243)
An armchair engineer speaketh.
Many times a heat related problem will be from someone installing an itty bitty black box in direct sunlight or perhaps attaching it to the muffler for additional nose weight. Tsk, tsk.
Ah, the first of numerous hypothetical questions like in the FASST Advisory that caused rational thinking to evaporate.
Temperature of Water-Time to Cause a Bad Burn
150°F (66°C) 2 seconds
140°F (60°C) 6 seconds
125°F (52°C) 2 minutes
120°F (49°C) 10 minutes
I'm surprised the said fuselage interiors didn't burst into flames or the canopys didn't wilt.
Give it a rest guys. It is beginning to sound like a chorus of poor, pitiful me here.
#33
The water burn numbers are relative to time which is what produces a burn.
For example the machinery I worked with (for clothing manufacturing -shaping and forming etc., was at 375f much of the time .
I had to design controls which prevented operators from accidentally contacting the "hot' areas.
anyway a brief touch on very thin metal did not cause a burn, as the skin cooled the metal.
The same time against thick metal did cause a burn- -it all has to do with heat mass.
On the electronics we see gradual thermal rise and gradual cooling -so the critical temp is easier to control as the enviroment of the electronics acts as a "heat control/ heatsink'.
Example: if the fuselage stays cool, the radio stays cool.
The fibre glass fuselages will heat the fastest
dark colors increase heat
tinted canopies reduce heat internally -a little
A white film covered balsa fuselage is the best, for heat control
Hows that for info you really did not need to read?
#34
Sometimes our models can be in a harsh environment. I'm only speaking to the 160deg F. I don't want get into the Brand war issue. Everybody's product can suffer under extreme conditions. When you live in hot environments you still want to fly model airplanes and we do. You don't have to put things into an oven to reach these kinds of temps. Its unfortunate that any product would suffer in this environment. We all want to play with our toy airplanes. I will say the environment can be very harsh. As a design engineer that deals with heating and Cooling issues as a part of me career field...I can tell you extreme heat loads are not limited to the middle of death valley.
A few years ago I was flying Electric pattern and we really starting to watch heat. Lipo batts and electric motors suffer under these conditions. This prompted me to take a very accurate IR temp gun and start checking temps.
I fly in Phoenix and yes even in the summer. Using a Raytek Temp gun we would check the ambient temp of objects around us then check the temps of the motors and batteries after the flight.
I started to check the temps of many aspects of our flying field before the flight just for curious sake.
Take an example a 105deg F day. In the hottest part of the day
On the shaded pit tables it was close to 105deg F
The gravel ground in the sun 125-130deg F
The blacktop pavement runway and starting area 157deg F
The white stripe on the runway 140deg F
The white Ultracoated wing panel moved from the shade to the starting area on top of the 157deg F blacktop. Was at 135degF.
Dark painted Carbon Fiber and Glass canopy on the model again just after coming from the shade and sitting it on the starting pad, 150deg F
I didn't leave the model in the sun just carried it out there and checked the temps. It was only on the pad for maybe a minute.
So we flew the model and landed. Canopy that is painted a dark color was HOT at 165-170degF the wings were still about 135degF
The model showed zero signs of bursting into flames, nothing melted, and it was taken back to the shaded table area. The electric motor and batts cooled down to the 105-110deg ambient temp and it was flown again.
So temps can soar very high in the hot sun. Not just counting ambient temps. Then running with a glow or gasoline engine will produce even higher heat sources internally to the models. Even the heat can "soak" through the firewalls and to internal components like RX's and batteries. Its unfortunate any of us have problems with our equipment, but the environment can be brutal at times.
I have only lived in Phoenix now for about 4-5 years. Yes we fly all year long and even in the summer during these hot temps. Covering the models or some shade always helps, but the temps internally in the models can easily reach the temps that are being discussed.
Just two days ago it was 111deg F and the hottest day of the year so far. I was not out flying but my back porch which sees late day direct sun showed 128deg F on the stucco wall. It it painted the same color as every other house in Phoenix, light tan.
By the way we have even seen temps in the model where the Li-ion batteries we were using went dead. As they went to an open circuit and 0.00Volts. Go to turn the model on and it doesn't respond. Check voltage and nothing....
I guess what I'm saying is don't underestimate the power of of the sun. And don't think because the weatherman says its 100degs today that objects in the shade or in the sun will be that temperature. The thermal properties of objects and the sun can really affect the temps of our components. A black servo or RX case sitting in a canopy area inside a fuse. No breeze to pass through to help cool the components by convection. Temps can soar very high and its still not bursting into flames.
Troy Newman
Troy Newman
#35
reasonable
I did not want to assign numbers but those are right in line with what I have seen (I also have a Infared gun)
I have see standard plastic canopies distort - badly - this takes usually 200 f. but lower temps and pressure buildup will do the same -I once saw one blow up like a balloon and pop and fall over - true story it was a old one -not made from PETG as almost all are now.
I am going to "shoot" some of my 6100/7000rx to see what is typical temp here - they are dark grey . my JR are light red - odd as it amy seem -the case color does make a difference.
My A123 powered models have minimal batt heat (as compared against LiPos ) even run at 50 amps .
Years back working with clothing manufacturers- we were informed that changing color of thread changed the setup on the sewing machines - really-
FWIW- Ya gotta know the territory-
#36
I have re-read my 9C, 9Z and 12Z manuals and related material that came with each system.
The 9Z manual makes no mention of heat when installing an Rx.
The 9C manual says to avoid extreme temperatures.
The 12Z manuals says nothing - the 12Z 2.4Ghz supplement provides the same basic language as the 9C - and says to avoid extreme temperatures - to mount the Rx as you did previous Rxs with the exception of the two antennas at 90 degrees.
There is no defininitive spec of what an extreme temperature is contained in any of the manuals or literature. The 60 degree C temp has been mentioned as extreme, but I have not found it in any Futaba literature.
The problem I have with using my 12Z on 2.4Ghz is one of am I willing to gamble everthing I own - that I could lose in a lawsuit if the worst happened. I can imagine being on the witness stand with a lawyer asking me why I was using a Futaba 12 Z with the 2.4 Ghz module and Rx.
Well you honor, I had read that there may be a problem with losing control of my 26 pound aircraft, but I didn't believe what I read - I thought it was all baloney - why Futaba is a great company - even though they wouldn't answer some direct questions about their product - wether or not there was a problem - even after a month of investigating. Yes I know that such a problem can be looked at in several days by a competenet engineering staff like I work with every day, but golly gee, these guys are in Japan - no your honor, I didn't think what I read was true and Futaba was good stuff. Sorry about hitting that kid riding a bike, but I don't think I am liable here.....
I just don't like to gamble - perhaps some do. Your choice.
Dan
Dan
#39
Ryan,
Yes you gamble when you fly - but due dilligence basically says you did everything reasonable to put your plane in the air in a safe manner - spectators can reasonably expect to not get hit by a run-a-way aircraft.
Example 1: I fly my Nieuport 28 with a Futaba 9C and PCM reciever - same as I flew last year. I check everything out. It all appears to all be good based on my years in the hobby. Something happens - I can state that I reasonably did everything I could to avoid such an incident.
Example 2: Someone new approaches me and askes me to check out their Nieuport 28 and give it a test fly. It is built just like mine. It has a Futaba 8UA Tx with PCM reciever. I personally know Futaba had a design defect on early 8UAs that would cause them to quit transmitting. There is documented evidence I know. I fly it anyway without checking that the Tx had the proper fix - something happens - I am in deep do do.
Right now there is a question about the 6014 failing if it is used in the same manner as we are all accustomed to. The documentation basically states this it should be mounted and used the same. I use it anyway - there is documentation on RCU that I knew about the potential risk and ignored it. In any lawsuit, I am dead meat.
Like I said, you can gamble - I don't like to given what can happen. I have had my share of mishaps over the years - hit a house once - but in good faith I did all that was possible to retain control over my aircraft. I lost control over a 26 pound Carden Extra 300 due to the 8UA - I still remember standing there praying it wouldn't hit anyone and cause injury - I just didn't want to see anyone get hurt - I didn't have time to consider a lawsuit.
I had my doubts about Futaba's system before the Toledo show - but one of their executives assured me it was one of the best systems on the market. Now there is a question and Futaba refuses to answer. It doesn't take a month to do an evaluation by a group of competent engineers - and I believe that Futaba has competent engineers - something else is going on - and I don't care to speculate here. What I do know is that Futaba is an industrial giant in electronics - not just RC. Yes, they have had the technology for years - but I believe they were pushed to market by Spektrum - in fact, I believe that if Specktrum had not brought their product to market, there would be no Futaba FAAST system right now - there would be no economic reason to do so.
Just my $0.02 worth.
Dan
Dan
#40
Certainly by now you know there are many park flyers available at toy stores that transmit on 72mhz. Do you still fly your aircraft on 72mhz knowing that some kid could unknowningly turn on a couple blocks down the street and send your 26 pound airplane into the crowd?
#41
TX
"due dilligence", your SO right ..... would shift blame to the truly RESPONSIBLE source!
For me there is only ONE way to go, JR with model match but the Futaba's that dont seem to have common problems seem to be just as reliable. So far i see as many bad as i do good.
2.4 frees me from worring about park fliers, Its kewl that the reciever ONLY listens to YOUR transmitter. ( except for those Futaba transmitters programmed with a common ID )
Several at my field on Futaba are talking about switching to JR/Spektrum..... Futaba really needs to catch up on problems AND do some kinda of model match, but we should have had modle match with pcm years ago.
I still see no reply from Futaba and the post ive done that werent all positive got deleted, Thats just plain wrong and will cost many planes and maybe a life or two .... open discussion is the only way to make the best of this, a forum that is a propaganda machine should be illegal!
#43
My Feedback: (243)
Some of you girls need to look around your shop and read, yes READ, the spec sheets that come with equipment you are using. Most electronic manufacturers provide a nominal temperature operating range and some RC manufacturers do also. It might surprise many that some servos, batteries, power boxes, battery backers, regulators, etc., have the same +60C (some less) max temp specified as the Futaba receiver!
So get a grip people and stop carping about a temp range that is common in our hobby. Our gear isn’t military spec so learn to isolate and protect your equipment from the -40C to +60C range.
And to the high dollar carpers in these forums flying 3W gassers, go read the copy silkscreened right on the ignition module….yup….Operating range -40C to +60C!
Get over it or go buy another brand if that makes you happy (sorry, but the operating temperature range is still the same).
#44
well said Dick.................
i just bought the 12Z and am not concerned that the reports about heat with the 6014 are an issue as i use common sense when flying my models on hot days.
in regards to putting a Rx of any kind under a canopy and having it exposed to direct sunlight, what are these guys thinking?[sm=idea.gif][sm=spinnyeyes.gif][sm=idea.gif]
what i do find amusing however is that Futaba has really put one of the finest 2.4Ghz systems on the market, and with the exception of the zero Guid scare, what else has really gone wrong under normal circumstances................it's almost like we have some "other brand" envy going on here and possibly just doing all they can to find an issue with Futaba.
what i do know from my past 30 years of using Futaba radios is that if there is an issue that creates a safety issue with their gear, they will make it right.
#45
I have to say that I am holding off a little on buying more FASST receivers until Futaba makes some sort of statement regarding the heat-related failures. I'd rather not purchase a receiver that I may need to send in for service. Having said that, the receivers I have are working great and I think the FASST technology is very sound. The ZGUID issue in the sport level radios was a manufacturing error, not a design flaw with the FASST technology. I just got my TM-14 module in the mail and am very excited to try out my new radio on my planes with 2.4 receivers installed. This new radio technology is certainly addicting!
#46
Ok. Let me get this straight. Futaba appears to have an issue that's come up with giant scale 3D airplanes. The issue seems to have only come up with those in AZ, as the seasonal temperature went up, in which the receiver is mounted below a clear canopy, in the direct sunlight, in one of the highest temp metropolitan areas in North America. None of these issues have been known to cause a single crash. Problems under other conditions (cooler ambient temp, receiver mounded under a canopy floor, painted canopy, covered airplane, ect) haven't been reported.
However, JR/Spektrum users seem to have had issues with receivers "browning out" causing crashes, and still seem to have issues losing their "bind". But since they're told just to rebind their radios, there's not a problem??? I've seen a handful of "unexplained" crashes with JR/Spektrum radios, where the airplane appears to go into failsafe, ect, causing the crash. I've never seen a Futaba 2.4 system do the same, but Futaba's the one with the problem?
It's amazing that people are making as big of a deal as they are. As has been said, most of the electronics aren't rated for more than 60C, so if you were to crash, how can you be sure it was because of the Futaba receiver, and not because your battery pack, ect quit due to overtemp?
People are also making a big deal because the Futaba support forum, which is run through Hobbico, the distributor of Futaba, won't give an answer before Futaba does more research and gives them an answer. And yet JR hasn't had a support forum for months. Maybe Futaba/Hobbico should do the same thing, so that people can't ***** about the forum.
Look at post #5 in this thread and see what you think.... http://www.rcuniverse.com/forum/m_7563203/tm.htm
#47
ORIGINAL: Flyfalcons
i agree with you though.....i'm holding off on 2 more Rx purchases.
it's fun going to the field and not even having to give a Rats butt when turning on the radio eh?
call it an old habit though, i still look around when i switch on to see if anyone in the air is being hit.........life is good
#48
ORIGINAL: mrjetpilot
#49
My Feedback: (243)
What does that sorry comment have to do with anything?
As I have already mentioned in this thread, RC equipment is not mil spec, and many other components we use fall into the same operating temp range.
So take off the “Savior” crown and get real. Bashing Futaba over the 2.4 equipment has become a sport for those with nothing other to blame or to wring their hands over.
Why not start a thread saving the 3D flyers from evil 3W. Gosh, their ignitions have a similar temp range and they go right behind hot cylinders or an oven baked firewall?
Boy, there a lot of sneaky manufacturers in our hobby.
#50
Dick,
Julez notes that that component is having the temperature range in question which means that the outside of the receiver needs to be lower for that component to not go out of spec as the the component, and other components too, will generate heat inside the receiver. Not everybody are electronics or heat engineers so stating this fact is good I think.
