JR R 921 2.4 Receiver +regulator problem
Old 05-22-2008, 01:20 PM
tuavp
Default JR R 921 2.4 Receiver +regulator problem
Hi all,
I have been trying to set up my JR 9303 2.4 system with 921 Receiver+fromeco adj.Reg so, if I connect the battery first to switch then switch to regulator then regulator to JR r821 receiver , system is not working, it does not bind and work. But if I first connect the battery to regulator then regulator to switch then switch to receiver it binds and works but in this case I can not shut down hole system I mean when I turn of the switch I only cut the voltage to receiver, regulator still works.
I tried this sytem with MPI regulator, Battery to switch, switch to reg, reg tor JR R 921 HIT it works and I can shut down all system just turn of the switch and I can charge as well.
I am not familiar with electronics. Can anyone tell me whats wrong with FROMECO ADJUSTABLE REGULATOR SYSTEM??? Why it works if I connect the battery first to regulator then to switch and receiver and why it does not works if I do the right and connect the battery first to switch then to reg then to receiver????
Sorry for my english and I hope someone can tell&describe me whats wron before I get mad:::::::::::::::::..........................
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
