14mz butterfly question
CA
What exactly is the offset button in the butterfly menu? I was adjusting it on a f5 plane and it now shows 100% and the function does not work, how do I reset it?
I used camber offset for the same function drop both ail to use as flaps but the camber offset is only on and off not linear???
on my 9z the function was called flaperons, WHAT FUNCTION ON THE 14MZ SHOULD i USE?
