New radio systems with 700 mAh batteries.
Are the 700 mAh battery packs that are currently the standard issue with most new radios really adequate to operate the average sport/aerobatic .60-1.20 size model using 4 or 5 servos. I know some folks will say that all radios use to come with 500 or 600 mAh batteries but for present day situations should upgrading to say an 800 mAh battery be considered as the way to go.
Karol
Karol
RE: New radio systems with 700 mAh batteries.
You should be able to get by with these, you will just be limited to fewer minutes of flight between charges. This is a good place to have a Voltwatch installed to enable you to easily check battery status after each flight to be sure you can safely get one more.
Thanks Rodney, as for keeping tabs on the available battery power I use a DVM with a simulated load feature to check the onboard battery's status after every couple of my usual 10 mins. or so flights .
Karol
Karol
KS
I read in one thread that the 2.4 radios draw less power and the 700 mah battery will last longer. I went ahead and bought a Lipo battery though. I'd hate to watch a plane fly away or crash because I ran out of juice.
What size lipo did you buy, anyway I'm giving it serious thought to change to some 800 mAh nicads from Hangtime Hobbies. Don't know why radio manufacturers don't get with it and supply batteries with larger capacity than 700, instead of only doing so for their top of the line models.
Karol
Karol
KS
Hi!
700mAh...? Over here in Europe most radios come with 1500mAh NiMH batteries.
But there are 2800mAh batteries available in all radio stores if you want to have more capacity.
My Feedback: (50)
MO
Does anyone else get the feeling we're not all talking about the same thing?
karolh, would you please clarify whether you're talking about the battery in the transmitter or the receiver battery in the plane. Judging by the responses, you're question is being interpreted both ways.
In your original post you ask, "Are the 700 mAh battery packs that are currently the standard issue with most new radios really adequate to operate the average sport/aerobatic .60-1.20 size model using 4 or 5 servos." That question leads me to believe that you're asking about the receiver battery. If that is the case, there are a lot of variables that should be factored into your decision. That said, I never use anything smaller than a 1500mAh Ni-MH RX battery anymoreeven in a 40-size plane. If you're using a JR/Spektrum 2.4Ghz system, I would strongly recommend a 6V RX battery if your servos can handle it.
My Feedback: (35)
MN
I was just wondering that the other day. Why the heck do vendors still include 700mAH receiver packs with a $300+ radio. NiCad none the less! Can you even still buy NiCad packs?!? LoL. I pull both transmitter and receiver packs and replace them with 2000+ mAh Nimh packs.
You are right in your assumption, but along the way the thread seems to have wandered to include the Tx also. Strange how times have changed as back in the late 70's when I ventured into R/C a 500 or 600 mAh battery pack was the order of the day.
Karol
Karol
ORIGINAL: foresterxt
