RS300 causing HS645MG steering problem
BC, CANADA
Hi, I have had two HS645MG before, and one TowerPro 995 steering servos with JR R300 servo. it all went bad for less than 5 play times.
So today I bought a new HS 645MG, and I took the receiver out to test the new servo, to my surprise, as I turn off my JR XS3, the Servo arm goes CW for about 130 Degree, I couldn't never make it turn like that with TRIM, or EPA function on the Tx.
However, as I turned the transmitter back on, the servo arms went back to normal nature position, and when I turned it off again, the arm didn't went crazy like earlier.
I am suspecting the R300 sent an error signal(due to whatever interference) to the servo as I turn off the TX. But this doesn't happy every time I turn off Tx, however I am guessing when it actually happens, with the servo mounted in position with the wheel arms (may be called servo saver arms ?), it will kill the servo. I guess my 3 servos was bad because of this.
Any ideas ?
Any ideas ?
