Expo went away on my 10X???
AB, CANADA
I got to the field this weekend and discovered the expo on my 10X had reset itself to 0% on all my planes. I usually fly with 60%. I flew my nitro bobcat first and had no problems handling it but still, why would this happen? Is it a know problem? Is there a way I can stop it from happening?
Dale
Dale
My Feedback: (13)
RE: Expo went away on my 10X???
Maybe you flipped a switch somewhere? I think the expo is remembered separately for each rate switch. So if you set the expo to 60% while the switch is on the high rate, if you ever switch to low rate the expo will be set to zero there. switch back to high rate and you will see the 60% again.
