Super8 5 Point mixing, how do you link the trim????
My Feedback: (7)
NJ
I want to use the 5 point mix on my Futaba Super 8 to program my 2 tail mounted elevator servos. The 5 point mix will give me 5 points of control over the travel of the servo to compensate for any differential (mechanical or in the servo). But there is no trim link on the 5 point mixers (mix 6 and 7) like there are in the standard mixers (mix 1-4). Kinda kills the idea because only my master servo moves with trim). Is the trim link hidden somewhere, or there a work around using a normal mixer in conjunction?
Thanks!
Thanks!
IL
Sorry, Nick, can't do it. There is no trim in the curve mixes.
You might try using the regular ailevator function and then do a channel 8 to channel 8 curve mix that makes your minor adjustments to the 2nd servo.
I personally select half a dozen servos and test them on the bench together until i get the 2 that are the closest possible match in travel and speed.
Sincerely,
Mrs. AnnMarie Cross
Senior Manager, Proprietary Services and Support
Great Planes Model Distributors
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
Sincerely,
Mrs. AnnMarie Cross
[email protected]
www.greatplanes.com
www.bestrc.com
NO AUTORESPONDER
