10C MIX
10C MIX
Hello
I am setting up a Baby Boomerang and i need some help regarding some mixes(Futaba 10C)
I need the nose steering wheel mixed into the retract switch so when i take the wheels up i need the nosewheel to stop moving but the rudders to work as usual all the time.
Can thoose of you that know this help me trough it so i dont have to use days to find out?
This is the setup so far
Ch 1 ail
2 ele
3 trottle
4 rudder(Y connector)
5 retract
6 Flaps
7 Ail
8???Nose wheel???
Ch 1 ail
2 ele
3 trottle
5 retract
6 Flaps
7 Ail
8???Nose wheel???
RE: 10C MIX
If you are putting the Ailerons on separate channels, put them on Ch1 and Ch7. Ch6 is the default for Flaps. You can mix the Rudders (Ch4) with the Nosewheel (Ch8). The Nosewheel is controlled by Pull-Pull cables, so the Nosewheel will not move when the Retracts are up.
RE: 10C MIX
The Nosewheel steering cables go slack when the Retracts go up.
If you have to Stop the Nosewheel servo from moving, when the Retracts are up, use a Pmix and make Retracts the Master and Nosewheel the Slave. Set the Nosewheel movement to Zero when the Retracts are up.
NJ
RE: 10C MIX
linear mix chan 4 master to chanel 8 nosewheel....
set the switch for the mix to the samw switch as the gear.....
when gear switch is up... mix off... no movement and I think it should return to center....
when switch is down.. mix is on... moves normal
NJ
RE: 10C MIX
just checked it out on my 10c
using p-mix 1 (1-4 will work)
the screen will read the following
Rate > +100%
< +100% (you can revese this to reverse the servo or set your steering travel)
offset > 0%
master > CH4
Slave > CH8
Mix > OFF
Trim >ON
Link >OFF
SW > swH (set to your gear switch)
Posi> DOWN (set you the position your gear is going to be extended)
Rate > +100%
offset > 0%
master > CH4
Slave > CH8
Mix > OFF
Trim >ON
Link >OFF
RE: 10C MIX
ORIGINAL: Unstable
Rate > +100%
offset > 0%
master > CH4
Slave > CH8
Mix > OFF
Trim >ON
Link >OFF
Rate > +100%
offset > 0%
master > CH4
Slave > CH8
Mix > OFF
Trim >ON
Link >OFF
The reason i need the nosewheel to stop is because i use Jet A1 and springair retract and the wheel will hit the wall if it moves in upwardsposition.
I will try and do the above after work
Thanks for the help
