JR 9303
Old 11-05-2008, 09:47 PM
rc-plane
rc-plane's Avatar
Default JR 9303
I just bought a new 9303 2.4 radio and I was wondering if I still need to fix the antenna wire? or have they fixed that problem?
Old 11-05-2008, 09:49 PM
rc-plane
rc-plane's Avatar
Default RE: JR 9303
I also forgot to ask but can you use Spektrum RX's with the 9303?
Old 11-05-2008, 10:08 PM
Wilki01
Default RE: JR 9303
I would pull the back off the TX and check, better to actually know yourself. It is very easy to remove. As for the Spektrum RX's, yes you can use them. I used both with my 9303 without any issues.
Hope that helps.
Wilki
Old 11-05-2008, 10:24 PM
rc-plane
rc-plane's Avatar
Default RE: JR 9303
Thanks!!!
Old 11-06-2008, 05:19 AM
Howard
My Feedback: (55)
Default RE: JR 9303
ORIGINAL: rc-plane
Welcome to the ranks of really happy JR9303 owners. Just for clarity it is not the the antenna wire but rather the wire bundle from the aileron potentiometer that chafes with the voltage regulator on the back panel. This is a link http://jrradios.com/Articles/HobbyWi...#HobbyWire1252 to the JR website area that deals with this issue. The fix is very simlple. I don't know about the Spektrum parkflyer equipment but the rest of it is completely interchangable for use with JR. One note is that the JR equipment has a 3 yr warranty and the Spektrum is one year.
Howard
Old 11-07-2008, 08:18 PM
John C
Default RE: JR 9303
The original Spektrum parkflyer Rx's (6000 I believe) work fine with the 9303. I have two in use.
John C
