futaba Campac compatibility
RE: futaba Campac compatibility
I used to have a Compac module sold by Don Edberg. It was a 256k module with four 64k sections. I had an 8AUPS and a 9CAP. Since the data from the 9CAP was not compatible with the 8AUPS, you could store model memories, for the 9CAP, in one or more of the four parts of the module, but you had to store the model memories, for the 8AUPS, in a separate part of the module. In other words, you could not import 9CAP model memories into an 8AUPS, and vice versa.
I used to switch my Compac module between the two radios and use a Momentary Switch to choose between 64k blocks.
