retract servo trim?????
It's late at night and working on my MW chipmunk..
I bought a GWS s136gm retract servo I have a R700 JR reciever and a XF631 transmitter.
I'm trying to reduce the travel on this servo through the radio but the servo will only go 180 degrees
Is this servo adjustable?. Should I use aa ssmaller control arm and use the 180 rotation.
Any input would be great!!!!!!!!!!!!
Banned
Most retract servos are not adjustable, and not proportional. They only go lock to lock so that the servo is not loaded at the ends of its travel. Measure the amount of travel that you need, then drill the holes so that 180 degrees moves that far.
Les
Les
Les thanks for the reply
I would of thought retracts were adjustable. Like they always say you get what you pay for!!!!!!!!!
RE: retract servo trim?????
Does anyone know where I can get a diagram of how the gears sit inside the S136GM servo ?
It failed on me the other day & I had to pull it apart & a few gears fell out, hope someone can help..
