Radio/Trainer Question
Hi,
I want to set up a "buddy box" to train with.
Can I use a Futaba Attack 4 4 channel AM/FM TX as the buddy box to a Futaba SkySport 4VF? Tha plane is set up with the Futaba SkySport 4VF as its radio.
Do I make the SkySport the "slave" to the Attack 4?
Thanks for any help.
Fezz
Fezz
UT
Unless Futaba made changes after I bought my AM Attack 4, this radio does not have a trainer port.
Regardless what radios you end up using, the radio which is setup to match the Rx frequency in the plane will be the master (teacher) radio, and the other one becomes the slave (student) radio.
Both Tx's need to be trimmed to match the plane.
