Can someone help DX7
TX
Hi guys, I purchased a Spektrum DX7 radio with the AR7000 receiver and I am completly lost on this one. I would like like to be able to control and adjust both aileron servos indepentant of each other and do the same with both elevator servos. Could anyone please tell me where I would connect the servo leads into the ar7000 receiver to be able to program these functions. Thanks for all your help.
My Feedback: (50)
MO
RE: Can someone help DX7
Check out Bob Pastorello's R/C Aerobatics Page:
[link=http://rcaerobats.net/Spektrum/dx_7_main_page.htm]http://rcaerobats.net/Spektrum/dx_7_main_page.htm[/link]
Lot's of information there. Look for the "Dual Elevators and Dual Ailerons (NO Flaps)" link under "Software" at the bottom of the page.
My Feedback: (89)
[8D]Go to page 39 in the manual, Choose Flaperon ON, Hook up ailerons as per page 41: Right Aileron in Aileron Plug (RX), Left Aileron in AUX1 (RX)
Note: Travel Adjustment, Sub Trim, Rev are set independent Right Aileron....Left Aileron is set with AUX1..Travel Adjustment, Sub Trim, Rev.etc (The Trim lever on TX moves both)
Note:Go page 38 and INH Aux2 Trim, INH Flap Trim....for Safety
Go to page 56 in the manual, Choose Mix #5..Setup: Master...Elevator, Slave...AUX#2, Rate: 100% ...100% (Requires movement of the Elevator Stick)
Hook up: Right Elevator in Elevator (RX)...Left Elevator in Aux2 (RX)
Note: Travel adjustment, Sub trim, Rev are set independent Right Elevator..Left Elevator is set with Aux2..Travel Adjustment, Sub Trim, Rev.etc (The Trim lever on TX moves both)
TX
Thanks guys for all the information. This is a great place to come to. Someone is always there to help you. Thanks again guys for making this a great site.
