What reciever for JR SX 3 ?
WI
I just bought a synthesized JR XS 3 remote. Can I use any fm reciever in future models and just tune the remote to it's channel. Or do I have to buy JR synthesized recievers only. I'm looking to buy a three channel Novak or JR reciever to save cash.
IL
For the Tx to be FCC compliant it must be
'on frequency' when channel is selected.
Any 'on frequency' Rx will work.
Note: Your XS3 radio system will only operate
either on 27MHz or 75MHz, not both.
Frequency Chart:
FREQUENCY.............CHANNEL
26.995 ....................1
27.045 ....................2
27.095 ....................3
27.145 ....................4
27.195 ....................5
27.255 ....................6
FREQUENCY...........CHANNEL
75.410 ..................61
75.430 ..................62
75.450 ..................63
75.470 ..................64
75.490 ..................65
75.510 ..................66
75.530 ..................67
75.550 ..................68
75.570 ..................69
75.590 ..................70
75.610 ..................71
75.630 ..................72
75.650 ..................73
75.670 ..................74
75.690 ..................75
75.710 ..................76
75.730 ..................77
75.750 ..................78
75.770 ..................79
75.790 ..................80
75.810 ..................81
75.830 ..................82
75.850 ..................83
75.870 ..................84
75.890 ..................85
75.910 ..................86
75.930 ..................87
75.950 ..................88
75.970 ..................89
75.990 ..................90
Frequency Chart:
WI
The radio does not transmit when in the channel switching mode. You have to turn it off and then back on for it to work. The radio is 75mhz. I just wanted to make sure that any reciever would work as long as it's on the selected channel.
Question #2
This radio is a three channel model, can I use it with a two channel reciever if I don't need the aux channel? Also what if I had a seven channel reciever, would only the first three channels work?
Question #2
