Range of the R610M Micro Receiver
My Feedback: (31)
NC
According to JR the 610 is supposed to be a full range rx.
The early ones were sent out with a shorter antenna than the later ones . If you have a blue dot stuck on the rx somewhere you have the full range version.
In any case the antenna length should be 39 1/2 inches. If yours is shorter than that you can return it and they will install the correct length antenna free of charge.
Hope this helps, John
JR state that 75 to 100 feet is what you would expect using a 39" long antenna.
The early R610M receivers came out of Japan with 60cm/24 inches of antenna for use in Park and Fly models.
DavidO
DavidO
