Hitec 645MG vs Hitec 5645MG
My Feedback: (212)
NC
I have a 28% plane with all 645's in it. Is there enough difference in the 5645MG to be worth the price.I have never used digital servos before.BTW I'm using a futaba 9c radio and a 6 volt receiver battery. Thanks
My Feedback: (14)
KY
RE: Hitec 645MG vs Hitec 5645MG
The difference can be explained technically. But to understand the difference in feel, you have to fly them. There is a difference in response that you can only understand when you fly the same aircraft with analogs and then digitals.
My Feedback: (67)
IA
I think with the digital's you can preprogram your Hi rates, nutrals and servo direction with a Hitec programer prior to installing the serov's in the plane. The digitals may cost more but I think you'll like them.
NEDYOB
NEDYOB
My Feedback: (44)
If you are going to upgrade, buy the HS-59xx or HS-79xx series, you will be happier in the long run. The HS-5645's IMO are not that much better than the HS-645 to spend extra money
ORIGINAL: nedyob
NEDYOB
NEDYOB
