Airtronics 97002 switch work with JR?
IN
Does anyone Know if a Airtronics 97002 Cs ser. 3-wire switch will work on a Jr or Spektrum receiver?javascript:void(AddText('[8\|]','))
RE: Airtronics 97002 switch work with JR?
Maybe[:-]
Only if that harness has "Z" connectors with the red wire in the center of the plug, as opposed to the outside with the old Airtronics plugs.
Pete
Pete
AB, CANADA
Any airtronics systems will work with JR, if you have the old system airtronics you need to switch the + wire from terminal one to the middle and make sure your signal wire is in the terminal one spot, so JR would go singal wire, positive, negative where the old airtronics systems go positive, signal, negative
