best range
NM
best range
curently i have a traxxas reciever and it wont even go as far as across the street. im looking into getting a new radio which would people suggest for 2 or 3 channel tx/rx ive seen futaba's 2 pl and ph but not sure wich one to get
RE: best range
It is most probably a bad receiver, could be crystal (there are two of them in the receiver, on plugin and one soldered in and either could be cracked if you ever jarred the receiver hard), antenna lose or broken inside insulation or a damage IF coil. Can you try a different receiver on the same channel?
NM
RE: best range
i opened up and all i found was a bit of dust so i cleaned it but the antenna i didnt do anything to it besides twist the end of it back down the tube and shrink wrap it
RE: best range
ORIGINAL: hpidrifternewb
NM
RE: best range
its not a joke. one end is solderd and he oher end comes out the plastic tube and i wraped it back around the top.
all i saw from jr is flying radios. spektrum im looking at the dx2.0 and futaba im loooking at 2pl
