SIMULATOR CABLE OF AIRTRONICS
TX
I am wanting to use my Airtronics 8000 on a simulator to learn to fly helis. Does anyone know of a source for the simulator cable? All I have seen are listed for Futaba.
RE: SIMULATOR CABLE OF AIRTRONICS
For the most part, each R/C Simulator has it's own USB cable with a small circuit board designed to prevent the Sim from working if you don't use their cable. This helps prevent Software Piracy.
Which R/C Simulator were your planning on using? The big names are Real Flight G4.5, Aerofly Pro Deluxe, and FS1.
Real Flight comes with a Transmitter. If you want to use your own, you need an Adapter cable that plugs in between the Real Flight TX and yours.
You can buy Aerofly Pro Deluxe with or without a dedicated Tx. I have always used my own Tx and the proper Adapter cable.
Aerofly Pro Deluxe has an excellent Support area in the R/C Flight Sim forum.
Check this out!!
This is the AFPD forum
http://www.rcuniverse.com/forum/forumid_337/tt.htm
Here is the general Flight Sim forum
http://www.rcuniverse.com/forum/forumid_138/tt.htm
ORIGINAL: cajun1
TX Buddy box plugs, Interface pin assignment
SmartPropoPlus - Connection via PC Microphone Socket - DIY for any TX
NB for Airtronics users, more information as above, is generally availablle under the brand name of "Sanwa"[which is howAirtronics is known outside USA].
See also sub Section "Buddy Boxes. Servo Leads. Flight Simulator & Interface." at:
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
