reducing bec voltage from 6v to 5v...
anybody ever try using an inline diode as a simple way to reduce the BEC voltage from 6v to 5v?
I've been testing the idea and getting it down to 5.18 volts, hoping that's close enough for the receiver to act properly.
any other ideas to do this would be greatly appreciated.
thank you for your time
~don
~don
RE: reducing bec voltage from 6v to 5v...
a diode has a forward voltage drop of anywhere between .3v to 1.6v depending on the diode type, material and forward current.
adiode inlne, or in serieswith the receiver should drop the voltage withoutaffecting the load(reciever and servos)
I'm just looking for someone else whohas tried it or has triedsomething else to reduce the BEC voltage from 6v to5v.
thanks guys.
~don
thanks guys.
~don
The diode will work with no problems. I have used them for years to parallel 2 battery packs in my larger models. Just make sure the diode current rating is equal to or higher than the current output of the BEC.
John W
John W
brilliant, thank you. just what I was looking for. someone who has been doing it for years.
thank you for your input.
as far as rated current, I usually apply the old military rule of electronics: figure out what your requirements are and doubleit for long working lifeand reliability.
thanks again and thank you to everyone who took the time to reply.I'm new to RC hobbies(even though I'm old) and it's hardto find good books on the subject. and information doesn't seem to be"stickied" at the top of the forums.
~don
~don
As stated, just ensure your diode can handle the current (a 1N4001 can only handle 1A at 50V max). Also, rather put 2 diodes in parallel (side-by-side) in order to up your redundancy.
Just remember that the diode will subtract 0.6V constantly, meaning that your bottom end will also be reduced with 0.6V
