Futaba 72MHz Rcvr Antenna Length
I need to replace/restore some Futaba R319 and R149 receiver 72MHz antennas that were cut to work with aftermarket base-loaded whip antennas. I don't have any other unmod'd rcvrs laying about to compare against. My recollection is that, independent of the freq band, these antennas are typically between 39 and 41 inches in length. Correct?
Thanks for any replies.
Mike
Mike
SD
RE: Futaba 72MHz Rcvr Antenna Length
ORIGINAL: Bax
1100 mm for 72 MHz.
1100 mm for 72 MHz.
<pre> This is a replacement receiver antenna for all Futaba FM receivers on the 72 MHz frequency band. All that needs to be done to install this wire is to solder it to the receiver. This antenna is used on older FM receivers such as the R128DF, R128DP, R129DP.</pre> |
The 1000mm part# LXH355is for
<pre> This is a replacement receiver antenna wire for Futaba receivers on 72MHz frequency band. All that needs to be done to install this is to solder this antenna onto the receiver.This will work for the R127DF, R138DP, R148DF. R148DP, and R149DP. This is also for the R168DF, R319DPS and the AFS PAR-2S.</pre> |
Don't know if there is a change but I just measured some receivers and all had 1000mm antennas
Jk
