Futaba 2.4ghz Receiver Problems!!!
hi,
i am currently using a futaba T6EX 2.4ghz transmitter and am trying to bind R617FS Receiver to it, but it just flashes green constanly which indicates ID is unmatched, does this indicate that the R617FS is not compatible with my transmitter?
Help
FL
RE: Futaba 2.4ghz Receiver Problems!!!
Your TX may have to go to Ripmax to get the RF board replaced. http://2.4gigahertz.com/techsupport/...m7-7c-6ex.html
The new FASST rx's will not link to a ZGUID tx.
Hope this helps.
Doug.
Hope this helps.
Doug.
Hi doug, thanks for replying, the site seems to be in America, i take it there is dealer in England that can deal with this, i`ll ring the shop i bought it from and contact his supplier.Damm expensive receivers thou!!! chaz@2b
Does anyone know a cheap source for R606FS receivers.
FL
Yes, that is why I said that you need to contact Ripmax in the UK http://ripmax.com/3index.asp?categor...electedtab=010
The problem is that your transmitter has a problem, they'll fixed for you for free.
Doug.
Doug.
CA
ORIGINAL: chaz@2b
The R606FS has been discontinued, but you may also want to look at the new R6106HF receiver FUTL7650. This is due late August and Tower has a price on this of $69.99.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
Sincerely,
Krysta
[email protected]
