Airtronics rds8000 binding problem
WA
I have a Airtronics rds8000 radio and I'm trying to use it with a new airtronics receiver in a new electric plane. The problem is that I can't get the radio to bind with the receiver. The manual doesn't address this type of use very well.
I must have a connection problem ? Does the esc plug into the battery port on the receiver ?
Norwester
Norwester
RE: Airtronics rds8000 binding problem
The signal lead from the ESC should be plugged into the throttle channel.
You might try using a rx battery plugged into the battery port to get the receiver to link to the TX and then plug the ESC in to the throttle channel. If the ESC has a BEC supplying power to the RX, don't use the battery and ESC at the same time.
Woodie
Woodie
