JR x378 aileron differential
I posted this in the JR forum but I thought someone here might know. I am trying to use aileron differential with an x378. As I increase the differential, the ailerons move more down than up. Shouldn't it be the other way around?
It sound like you have the aux 1 connected to right aileron. it should be aux1 to left aileron. swap them over reverse servo's then if im right voila!
I will check which aileron is in the aux port. I can't remember off the top of my head. I figured out how to set the end points separately through the travel adjust process and that seems to have taken care of the problem.
