Reverse Throttle Response Needed
WA
Anyone have any experience with these new Sky-Fly 2.4 Ghz Transmitter/receivers? I have one I am trying to use with a Aquacraft ESC/motor and when I arm the ESC, the throttle response is backwards. In other words, letting out the trigger gives throttle. Any ideas how to change this response? Manaul is not reall beneficial.
WA
RE: Reverse Throttle Response Needed
Yea, I tried that on the Transmitter. The transmitter indicated reverse but it did not work. Tired it both ways too. I used a proboat AM transmitter and receiver and I had to take the throttle trim all the way to reverse to get it to work right but it did. This Sky-Fly Transmitter has three different locations to mess with throttle and they allow a range from 0-100 for sensitivity. I will keep trying.
WA
Ok. A bit more information. I am using this transmitter with a SuperVee ESC. To arm this ESC you connect the batteries. It beeps, you pull the trigger, it beeps again, and you let go the trigger and it beeps (manual says five) 4 times. This arms the ESC. What it is doing with this transmitter is beeping until the trigger is pulled, beeps once when the trigger pushed the opposite direction full, and then pull the trigger again all the way back and it beeps 4 times and arms. Unfortunately, this is when the trigger is all the way in and it throttles and the trigger is let out. Seems like an ESC problem, not a transmitter problem. Reversing the transmitter only reverses the order in which the ESC arms. Ie all the way forward vs all the way back before it arms.
It has been a long time since I set up an electric, but I seem to remember in the days before programable escs that you could just switch two of the three motor wires and that reversed the directionl.
PA
> you could just switch two of the three motor wires and that reversed the directionl.<
He is not talking about motor rotation, but the direction of the throttle stick.
WA
Switching the motor wires just makes the motor run in reverse, right? This problem is with the throw of the throttle trigger (ie trigger response). However, I'll switch them tonight and let you know if that works.
