Spektrum DX7 Dual Elevator Setup Help
Hello,
I'm setting up a 50cc Extra 330 and using dual elevator servos. I have set the programming up like this: http://www.rcaerobats.net/Spektrum/d...l_ailerons.htm
Everything works except my dual rates only work when the elevators go down. When they go up dual rates only work on the right elevator the left elevator does nothing. I must of missed something.
Can someone please show me what I did wrong.
Thank you very much!
Mike
Mike
My Feedback: (89)
RE: Spektrum DX7 Dual Elevator Setup Help
[8D]Try this:
DX-7 Dual Elevators
Go to Mix#5 (Allows use of trim)
Setup: Master Elevator
Slave Gear
Rate +100 %
+100 %
Go to Mix#1
Setup:Master Gear
Slave Gear
Rate -100%
Rate -100% (You may have to flick the Gear Switch)
This inhibits the Gear Switch
DX-7 Dual Elevators
Slave Gear
Rate +100 %
+100 %
Go to Mix#1
Setup:Master Gear
Slave Gear
Rate -100%
