servo tester
WI
servo tester
Is there a servo tester i can buy from a hobby shop. which are the best for your buck. I have looked on the internet, lots of u build your own and a servo tester # 555. Can i get some input from rc modelers on which brands and models are out there. do they check amperage readings on a servo ??
Any help would be appreciated.
thank you
thank you
RE: servo tester
ORIGINAL: M3220 Is there a servo tester i can buy from a hobby shop. which are the best for your buck. I have looked on the internet, lots of u build your own and a servo tester # 555. Can i get some input from rc modelers on which brands and models are out there. do they check amperage readings on a servo ?? Any help would be appreciated. thank you
Hitec HFP-20 The HFP-20 directly replaces the HFP-10 and allows users to perfectly match servos in ganged applications or customize several other parameters such as dead band, direction, speed reduction, endpoints and failsafe. The HFP-20 is required to program the overload protection features in the new HS-79XX and 50XX servos along with the standard/high resolution setting in the HS-79XX series. The HFP-20 is backwards compatible and works with all Hitec Digital Servos.
Programmable Features Include:
Reset to factory default
End and center points
Direction of Rotation
Dead Band Width
Failsafe Point
Speed (reduction only)
New G2 Servo Features:Overload Protection, Resolution Mode Setting
Hitec HFP-21 PC Programmer for Hitec Digital Servos
. PC Based Digital Servo Programmer and Tester
. Programs all Hitec Digital Servo Parameters
. Tests all Brands of Servos
. Free Downloadable Software
. USB PC Connection
Hitec HPP-21 Plus PC and Field Programmer for Hitec Digital Servos
. Digital Servo Field/PC Programmer and Tester
.Tests all Brands of Servos
. USB PC Connection
. Less Expensive Alternative to HFP-20
See also sub Section "Servo - Alterations, Calculators, Databases, Leads, Repairs," under
"Radio Systems, Accessories, Alterations and FAQ." and DIYElectronics at:
Alan's Hobby, Model & RC FAQ Web Links
Regards
Alan T.
RE: servo tester
I've used the Vexa ServoXciter for years. I'm very happy with the results.
http://www.vexacontrol.com/
RE: servo tester
Hi,
I have one from Hobby King and did a quick search there, I'm sure they have more - this is what I found. You'll have to pick one with the features you want.
HK Servo Doctor = $38.62
http://www.hobbyking.com/hobbyking/s.../_Gyro_Sensor_
Turnigy Servo Testor = $5.99
http://www.hobbyking.com/hobbyking/s...idProduct=8296
Turnigy 760LV-HV Dual Pulse Width Selectable Servo Tester =$7.99
http://www.hobbyking.com/hobbyking/s...dProduct=11780
GWS Servo Tester MT-1 w/ Manual-Auto select = $25.20
http://www.hobbyking.com/hobbyking/s...idProduct=4573
Fly4Fun,
Wayne
Fly4Fun,
Wayne
RE: servo tester
ORIGINAL: tenglish Hi Alan, I have a HFP-20 which works fine on most Hitec servo, but on other Hitec, JR ect, is erratic.
Any ideas? Regards, Terry
Most problems stem from a low battery.. how old is the unit?.
Suggest remove & cycle battery, check battery connections/leads inside & out, other wise please refer to
Hitec Warranty & Service
Regards
Alan T.
My Feedback: (7)
RE: servo tester
You might also try the following site for their YTV Servo Cycler & Driver. works great for testing, ensure centering and cycling
http://www.york-electronics.com
RE: servo tester
I started to add the following as choice, http://www3.towerhobbies.com/cgi-bin...&I=LXVK79&P=ML , and then noticed it was only a year ago that he asked the question[:@]
