2,4 ghz cheap radio
2,4 ghz cheap radio
hi
im looking for a 3ch 2.4g radio and receiver combo for my Team Losi LST2
i dont have a lot of money to spend, about 100$-200$
i have seen some cheap one on e-bay that goes for about 50$-100$ but none of them have EPA or features that are important
i just want to know what kind/brand of radio i should be looking for or if you have any suggestion on wich ones are good in my price range
thanks for your help
TX
RE: 2,4 ghz cheap radio
seeing as how you have a fairly nice budget airtronics mx3 is fairly good dx3 s is good as well but a lil over your budget , futabas dx3 sport is 149 bucks also throwing this out there for the best cheapo radio , the eurgle 3 channel it has all the features except a built in fail safe
I have one of the Eurgle radios. It is the 3rd generation and is said to now include a failsafe, although I have not found a way to adjust it, but I tested it and in the event that I turn off my transmitter while the car is running, it immediately drops to 0 throttle. Failsafe aside, it was only $60 and it does everything I need it to. Construction of the actual unit itself is really rough (you can see a "glue fingerprint" on the inside of the lcd screen) and I worry about the quality of the plastic the Tx is made from, but its operation so far has been flawless. 8 model memory, end point adjustment, abs, dual rate and expo, it really does a lot for the price.
Hey Folks...
Try Tower Hobbies, they're selling 2.4Ghz Tx for under $160.
4YF 2.4GHz FHSS Spt Tx/Rx/4 Micro Hi-Torque Servo Combo:
http://www3.towerhobbies.com/cgi-bin/wti0161p?&I=LZ1036
4YF 2.4GHz FHSS Sport Tx/Rx/4 Standard Servos Combo :
http://www3.towerhobbies.com/cgi-bin/wti0161p?&I=LZ2236
