Analog/Digital Servos in 1/5 - 1/4 Scale
My Feedback: (25)
Is there any particular reason to use digital servos in a non-3D 1/5 - 1/4 scale aircraft. I.e., as a group, is there a particular reason to use one or the other in a sport and simple aerobatic environment in this size plane running a 30-50cc gasoline engine. thanks.
RE: Analog/Digital Servos in 1/5 - 1/4 Scale
I do not think you have to use Digital servos for everything. I still use Hitec 645MG servos for some planes. If I need a Faster Response or More Precision, I use Digital servos. If the Price Difference is negligible, I will opt for the Digitals.
Ditto to what BB said
I would add, that a couple of weeks ago I had an ignition/RF problem, due to a new spark plug having a loose screw on tip (I now know you have to tighten them[:-])
The 5 Hitec digitals were oblivious to the RF noise, only the analog Hitec on throttle was going nuts above half throttle. I don't know if there is a difference in how the digital servos handle RF noise induced into the servo leads as opposed to analogs, but if my flight surfaces were acting like the throttle servo, I would have lost the plane for sure[:-]
Receiver was a Futaba R617FS FASST. I'm sure the problem was noise in the servo leads, BTW 4 of the 5 digitals were on much longer leads, the throttle had no extension at all.
Pete
Pete
NY
I use the Futaba S3010 Std size/ high torque servos in my 1/4 scale cub....It has lots of power that I really don't use, but it's there if I need it, and std speed 'cause it is a Cub, it doesn't do much at a high rate of spped. At 25 bucks each they are easy on the wallet. Hitec 605's and 645's are popular in my collection as well.
Good Luck, Will
Good Luck, Will
