JR/DSM2.4
RE: JR/DSM2.4
The question was whether the JR/DSM would work with the AR9000 Rx which is DSM2, I believe.
Isn't the DX6 a DSM radio and it won't work with an AR7000, for example? The DX6i will because it is DSM2.
http://www.rcuniverse.com/magazine/a...article_id=623
http://www.rc-airplane-world.com/spektrum-dx6i.html
VA
RE: JR/DSM2.4
Thanks, I hooked it all up and the JR remote (DSM) will not power up with the AR9000 (DSM2).
Off to the hobby shop.[sm=regular_smile.gif]
RE: JR/DSM2.4
Did JR ever make a DSM anything? And the remote receivers were all a result of DMS2 full range systems. I've never mixed/matched JR/Spektrum main/remote receivers but a JR DSM2 receiver will work fine with a Spektrum DSM2 transmitter. And, of course, a Spektrum DSM2 receiver will work fine with a JR DSM2 transmitter.
RE: JR/DSM2.4
The only aircraft DSM receiver that I’m aware of is the AR6000, which doesn’t use a remote. I’m using Spektrum and JR remote receivers on my JR 921 receiver. The remotes are all DSM2. If the JR remote doesn’t work on your AR9000, you most likely have an equipment failure not a mismatch.
Allan
VA
RE: JR/DSM2.4
The TX is a 9c with a Spektrum module and AR9000 RX. I went and picked up a Spektrum remote, rebound the receiver and everything works fine. I'm thinking bad new remote out of the box. Just a guess.
VA
RE: JR/DSM2.4
It was in PPM. The AR9000 and the one remote worked fine, it was only the JR remote that would not power up when the system was turned on.
