DX7 and 4 Site Flaperons Setup
Hi everyone,
I'm trying to setup flaperons on my DX7 with the AR6700L, been messing around all day, but can't get it to work.
I have dual aileron on ultra micro 4-site.
I now have:
Left Aileron in channel AUX1
Right Aleron in channel AILE
Now I think I have to do something with the MIX1 and maybe MIX2, but I have no idea.
Is there anyone that can point out how to setup Flaperons?
I like to know how to setup the transmitter to control each independently.
Thanks!!
RE: DX7 and 4 Site Flaperons Setup
You have the servos plugged into the correct channels (Right Aileron into Ch2 and Left Aileron into Ch6). You just need to enable the Flapperon program. You do not need to use any Programmable Mixers. If your aircraft had separate Ailerons and Flaps, then you would not use the Flapperon program.
You will find that this is common with almost any computer radio.
Can I do setup on DX7 and make the Aileron Stick works like Flaps movement with stick input after flip of AUX switch? I do not like to flip switch to get fix amount of preset flap. Can we assign the Aileron or Elevator sticks with a flip of a switch it would be great?
