HiTec 7940 TH HV
RE: HiTec 7940 TH HV
ORIGINAL: gpw4653 Does anyone have any info on HiTec 7940 th hv servos?
This is Hitec's fastest standard size servo. The "Ultra Speed" HS-7940TH is designed to operate on a two cell LiPo Pack. Featuring high resolution "G2" second generation programmable digital circuit and indestructible Titanium gears, The HS-7940TH has the performance and durability you've come to expect from a Hitec servo. Other features in the HS-7040TH include a 7.4v optimized coreless motor, integrated heat sink case, and a top case with two hardened steel gear pins supported by axial brass bushing.
The HS-7940TH has been designed for applications where speed and response is demanded. Perfect for High Performance Nitro and Electric Helicopters.
Specs:
-Motor Type: Coreless
-Bearing Type: Dual BB
-Speed: 0.07 / 0.06 sec @ 60 deg.
-Torque: 181 / 222 oz./in. (6.0v/7.4v)
Detailed Feature Descriptions
-G2 Digital Circuit
-Titanium Gear Train (MK first gear)
-Ultra Performance Coreless Motor
-Heatsink Case
-(8) O-Rings for Water/Dust/Fuel protection
-Dual Ball Bearing Supported Output Shaft
Programable Features Include:
-Dead Band Width
-Direction of Rotation
-Speed of Rotation (slower)
-End Points
-Neutral Points
-Fail Safe On/Off
-Fail Safe Point
-Resolution* (default is high resolution)
-Overload Protection* (default is off)
*These features are only programable with the HFP-20, HPP-20 or HPP-21 programmers.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
