Hitec hs-5085mg adapter / mount question
NY
Hello.
I working with a set of hs-5085mg servos, each having two plastic parts- they appear to be some sort of mounting adapters that I've never seen before. I think I figured out how they attach to the servo, but I'm not sure.
Has anyone ever used these? what are they used for? How do you attach them to the servo?
thanks.
thanks.
NY
RE: Hitec hs-5085mg adapter / mount question
ok... here's a pic.... It's the black "T" looking parts at the top-center of the pic. What are these for and how are they attached/used?
thank you.
thank you.
NY
Thanks. That's what I was thinking. But when I attach them to the servo, there's a ton of play. I dont think I attached them correctly.
Has anyone else used these things?
Hello Folks,
I happened on this thread while searching for parts for the HS-5085MG servo. I have attached a photo of the servo with the mounts. I left the one on the left loose slightly to show how it mounts. Ignore the pot outside. I am modifying this servo so I can drive a gear almost 360 deg. The pot will mount to the spur gear. Hope this helps.
Regards,
Dennis
Regards,
Dennis
ORIGINAL: debtman3535 ok... here's a pic.... It's the black "T" looking parts at the top-center of the pic. What are these for and how are they attached/used? thank you.
As per previous posts. Units have beenpreviously enclosed with HS-85, see also
Hitec Servo Accessories
available separately as follows, pictures attached.
HS-56306 Vertical Mount Set (4pcs) For (HS-60/ 81/85BB) without horn&screw set.
HS-56327 Vertical Mount Set (4pcs) For (HS-60/ 81/85BB) with horn&screw set
HS-56307 Universal Micro Servo Wing Mount Set for HS-85BB, Fut FP-S143, JR NES-341, Airt 94501 servos.
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
