Help With Box Starter Please
Hi Everyone
A noob question coming up...........................
I purchased a usedbox starter off eBay, it works fine, I've set it up correctly but when I place the buggy on it, it dowsn't turn the flywheel, it just stops.Should I have done something to the buggy, like remove the pull starter? Sorry it sounds a bit dumb but I'm an RC newbie.
Cheers!
Cheers!
RE: Help With Box Starter Please
ORIGINAL: twincamms Hi EveryoneA noob question coming up...........................
I purchased a usedbox starter off eBay, it works fine, I've set it up correctly but when I place the buggy on it, it dowsn't turn the flywheel, it just stops.Should I have done something to the buggy, like remove the pull starter? Sorry it sounds a bit dumb but I'm an RC newbie.Cheers!
either could be stopped due to battery(ies) flat and/or old and no longer producing amps. laters' belts slipping?
2. Engine flooded or compression to high. >. Many glow plugs for car and boat high compression engines have a torque bar so glow plug can be loosened 1/2 turn and tightened when engine starts..
Perhpas best if question moved to:
Car Nitro & Gas Engines
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
