Futaba 9C Mixing question....
My Feedback: (32)
MA
Hi,
I've got two elevator servos working on a giant scale model using one of the pre-programmed mixes ('Ailevator?). If I go and add expo to the 'Elevator' channel, does that automatically add the expo to both servos?
John
John
RE: Futaba 9C Mixing question....
End points and sub trim are unique to each channel though. Keep that in mind when setting up the plane. Use the sub trim to set the neutral point on both halves of the elevator at the same point. Servos with no sub trim supplied will center differently on opposite sides of the plane. The same in relation to the servo housing , but differently in relation to the air frame. This would be your first trim. Then verify the end points are the same.
Don
Don
