HobbyKing OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
#151
AZ
I have several FR-SKY receivers. They all work good but then I am using an FR-SKY transmitter.
I hear the comment "cheap Chinese receivers". I agree they cheap. But I have dissembled a few and I can assure you the workmanship is first class. Just because they are cheap does not make them bad.
I am a retired Boeing electronics engineer. The items we got from China when I was working, were superior, and cheap.
#152
IL
I have a futaba 7c and I have my eye on this too...90 bucks is silly IMO for a receiver. The problem I have with the HK receiver is that if you buy a cheap motor, cheap airplane, cheap hardware, cheap servos, cheap battery, etc you can usually find out if what you bought is crap ON THE GROUND. With a cheap receiver, the only way to find out for sure is IN THE AIR. THAT'S the problem I have with this.
I guess in a $90 arf with a $50 engine and $10 servos it's not a bad risk. IMO the best news about this receiver is that if it does in fact prove reliable, word will get around and Futaba will eventually be forced to lower the price of their faast receivers
#153
My Feedback: (15)
FL
Don't buy anything from HobbyKing. It's junk and if you have any problems with anything, just throw it away. Dealing with them is like communicating with a 2 year old child that is just learning to speak English. No hablo English, no hablo Chink.
#155
TX
I'm now leaving Futaba in favor of the new Spektrum DX9. Call me a turncoat. Have (2) 6 EX's . Have used Frsky fasst, Corona and Orange. All work fine. I'll be selling a bunch of these including a genuine futaba fasst rx . Been getting the Frsky's from Value Hobby in Chicago. The only negative is that they don't seem to like Dynam retracts. No problem with the Corona's.
#157
My guess is they are going to clear these out and replace them with a new one that supports FASST and FASSTEST and maybe FHSS too. Hopefully it will be in this price range.
The compatible market has started to mature and the products are getting better and better so maintaining the high price for their receivers will be hard.
Starting to feel like the 72 MHz days. I like it!
#158
Futaba really coming through with this one
#159
+1 on that!!
I just had just had a very bad crash due to CA hinges pulling out of the elevator, she literally bought the hay field at WOT. My one R607FS was torn out of the case and the antennae coax connectors are no longer tight after the crash. Time to bin it!
I'm sure this is an indication that there will be an updated 7 CH receiver, possibly one that will link either in 7CH mode, or in MULTI mode to provide settable failsafe on all channels. That said, the R617FH has been a bulet proof receiver for a long time
Pete
Pete
#161
My Feedback: (98)
I just received my Hobbyking Fasst 2.4 rx after waiting a month for it. Just the rx in a yellow mailing envelope. No instructions!! Was told it shipped and was given a Tracking # that did not work. After 2 emails and 2 weeks later I finally received a tracking # that worked. @ weeks later it arrived at my door. As above stated customer service is almost non exisitent. Anyway I hooked it up to my FMS P38 and immediately smoked 3 of the 9 servos installed in it.And when I say smoked I mean they litterally smoked and melted the case before I could disconnect the battery. All of the servos chatter and get pretty hot. It is now in the garbage and I will not be dealing with Hobbyking anymore. To many other good places to buy from.
#162
There are instructions you can download for it on the website. Here http://www.hobbyking.com/hobbyking/s...84X7478X18.pdf
Look at the warning in red in section 3
Warning: HS Mode is only applied for high-speed digital servos. Other servos should select FS Mode, otherwise servos will get hot or even burn out.
#163
TX
Sorry to hear about your horrible experience.Very strange that an rx would take out your servos. Sounds like a voltage glitch. I've bought a lot of stuff from HK and had a few gtrials and tribulations along the way but for the most part , okay. When there is an order problem, it's best to hang out on their chat line. I just lowered my expectations with them, especially with shipping. Bought the Frsky fasst rx's from from Value Hobby. Have also used Corona and the real McCoy, Futaba. $70-$80 bucks for a 6 channel 617? Now I'm almost 100% switched over to Spektrum( I know, I'm a traitor) so if anyone needs one, I've got a bunch of them.
#164
SD
Good luck
#165
IL
well well...it looks like the HK receiver just fulfilled it's intended role...$77 for 2 fasst receivers, plus 25 off when the order totals 150, and no shipping from tower. THis makes the fasst receiver the same price as the HK receiver. This makes the fasst receiver sufficiently cheap that I wouldn't take the HK unit if it was FREE! Thanks HK, nice work!
#167
The Futaba 8J does not use the FASST system. It is based on Futaba S-FHSS
http://www3.towerhobbies.com/cgi-bin...&I=LXBWGR&P=ML
FASST and S-FHSS are not compatible so that receiver can't be used with that radio.
#169
Here's a FrSky receiver you can use with your 8J.
https://alofthobbies.com/frsky-delta-8.html
Also dealing with Aloft as opposed to Hobby Kong is a world of difference if you're in the US.
Pete
Pete
#171
You live, you learn. You buy, you return.
With HK sometimes you are better off selling it to a friend. Last time I tried their return process left much to be desired. I only buy things from them that are cheap enough for me to throw away if they arrive dead. Or sometimes I buy two figuring one will work. If they both work, BONUS!
#173
Yeah the Delta 8 receivers are great - I was using two with a Futaba 14SG (This TX has FASST and FHSS) - when I switched to a Taranis it only required a re bind and they work with that radio too. A very versatile RX.
#174
I just bought a FUTABA 16SZ transmitter . It works o.k. with the FUTABA R7008SB ,COOLTEC RSF08SB & CORONA R8SF in Fasstest and S-FHSS protocols .
Also with Corona GR7FA and Redcon FT8RSB in FASST and FASST MULTI .
It does not work with the OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver.
I cannot get it to bind with my Futaba 16SZ. The green light comes ON but not steady and the responce from the servos has a delay , so i can not use them (and there are 10 of them ).
All the OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz receivers are working perfectly with my FUTABA 9c super...
What am I doing wrong?
#175
My Feedback: (243)
Did you try 7 channel mode? The TM-7 and TM-8 Futaba modules operate a little differently than later built in protocols.
The flashing green but no link is exact results I get when trying to link a Futaba 8 channel receiver with the TM-7, links fine with a TM-8. The 16SZ FASST and FASST-Multi may have different channel timing than what the Orange Rx can respond too. If it does not work in 7 channel mode then likely the receivers are at fault, not defective, but unable to work properly with the 16SZ.
