HobbyKing OrangeRx Futaba FASST Compatible 8Ch 2.4Ghz Receiver
#176
My Feedback: (19)
To switch between HIGH (digital servos) speed and LOW (analog servos) speed mode:
Turn transmitter OFF
Turn receiver ON
Press and hold the F/S button for 6 seconds
The Red led will flash fast in high speed mode, and flash slower in low speed mode
#177
Dick T. & Dave McDonald , thank you very much for your answer . I use TM-8 Futaba and the receivers in LS mode and they work fine . They are in LS mode in 16SZ also, but the servos have a delay in action and they do not "center " in the middle ....every time in a new spot ... i believe i must buy a new series of receivers..
