Turnigy 620DMG+HS High Torque Digital Servo (MG
Anyone use or know someone that has Turnigy 620DMG+HS High Torque Digital Servo (MG
Any good the reason I ask I just bought a great plans yak 25% with a DLE 55 and it has these servos in it they seem supper fast and strong on the ground they are noisy hear are the specs Turnigy 620DMG+HS High Torque Digital Servo (MG) 10.6kg / .13sec / 52g Turnigy 620DMG+HS High Torque Digital Servo (Metal Gear)10.6kg / .13sec / 52g Double ball bearing (Si-oil) CE Certified Strong 3 Pole Motor Heavy duty sealed water proof case Alloy heatsink Digital signal design with 100% fitting square PWS Automatic measures central ms ALU 6061 alloy and C95 gear material Digital IC (SOP package with 12bits transfer data) MOS-FET driver (spirited driver able to push over 7A power) Weight: 52g / 1.84oz Dimensions: 40.5 x 20 x 42mm / 1.60" x 0.78" x 1.62" Torque At 6.0V: 10.6kg/cm , 190 oz/in Speed At 6.0V: 0.13 sec / 60° at no load Operating voltage: 4.8 - 6.0V |
RE: Turnigy 620DMG+HS High Torque Digital Servo (MG
Can't tell you about that servo, but these servos from HK are super. (D-MG16 Metal Gear 2.9kg/.08sec/18.8g
1 Attachment(s)
<span style="font-family: Verdana, Arial; font-size: larger; "><span style="font-family: Verdana; ">HIV titanium geardigitalservos,High torque and high speed.Wonderful performace on rc cars,helicopters and airplanes.</span></span><span style="font-size: larger; "><span style="font-family: Verdana; "><span style="color: rgb(255, 0, 0); ">Click here</span></span></span><span style="font-family: Verdana, Arial; font-size: 13px; background-color: rgb(251, 252, 255); ">
<br type="_moz" /></span><br style="font-family: Verdana, Arial; font-size: 13px; " /> |
