7c fasst
I have an old futaba 7uafs, and after a maiden you can (trim reset) and then your able to move trim levers back to neutral position. Can you do this with new 7c fasst radio?? Doesn't look like you can.
Just got this radio, so not very familiar w/ it yet.. |
RE: 7c fasst
ORIGINAL: tech1wi I have an old futaba 7uafs, and after a maiden you can (trim reset) and then your able to move trim levers back to neutral position. Can you do this with new 7c fasst radio?? Doesn't look like you can. Just got this radio, so not very familiar w/ it yet.. Some radios still have Analog Throttle Trim. |
RE: 7c fasst
Look up Sub-Trim in the manual. You can visually center a control surface if it was off mechanically or visually move the surface the amount required for level flight.
RE: 7c fasst
ORIGINAL: Dick T. Look up Sub-Trim in the manual. You can visually center a control surface if it was off mechanically or visually move the surface the amount required for level flight. The first thing I do with a new Model Memory id to Reset to Factory Defaults. Next, set the Servo Direction. With the servo at Neutral, install the Servo Arm as close to 90 degrees as possible. Now, use a minimal amount of SubTrim to get the Servo Arm to 90 degrees. |
RE: 7c fasst
100% agreement here. I remember the days before sub-trim where mechnical adjustment was the only way to set up controls and to final trim a model.
Today's radios provide so many ways to make it easy but only if you know where to start. |
RE: 7c fasst
ORIGINAL: BuschBarber Some radios still have Analog Throttle Trim. |
RE: 7c fasst
I too like the Analog Throttle Trim!!
RE: 7c fasst
ORIGINAL: BuschBarber I too like the Analog Throttle Trim!! I agree with you . I own both types but analog does have positives on its side . The major positive for digital trim is the mode change feature . I fly mode one and it would be easier to sell my used but not abused equipment but I would not make my selection for that reason alone . When the JR ten series went to digital trims HH did a rather extensive study and survey . The results were that the preference was for the 3+1 trim set up . So here we are. |
RE: 7c fasst
Digital for me. With Futaba radios you can assign any function to any switch, something I can't do with my 9303.
I assign throttle cut to the trainer switch and I'm done. Doug. |
