RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   *SD-10G Idle Up Switch* (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/10595871-%2Asd-10g-idle-up-switch%2A.html)
Zippi 06-28-2011 03:18 AM
I'd like to set up a switch for my electric planes so just before take off I can hit the switch and have the motor just barely turning. How can I set this up???
karolh 06-28-2011 03:48 AM
RE: *SD-10G Idle Up Switch*
I am interested too.
Karol
ArchNemesis 06-28-2011 04:15 AM
Use the Idle Down function.   Set your throttle trim allllllll the way down.
Then set your Idle Down to a switch (In the main menu, you can assign that to any switch you choose, I use #1)
Then in the Idle Down menu, you can set the value that starts the prop spinning.  I usually have it just a few clicks above that.
When you plug in your Batteries, if you're using fixed endpoints, your ESC won't initialize until you turn the Idle down OFF, and then when you turn it back on, the prop will start.  Works very well...
Let me know if this made sense.
karolh 06-28-2011 04:30 AM
On behalf of Zippi and mysef, thanks.
Karol
Zippi 06-28-2011 09:03 AM
ORIGINAL: karolh
Karol
Yeap, I'll have to give this a try. Thanks alot dude.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
