RCU Forums
-   RC Radios, Transmitters, Receivers, Servos, gyros (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/)
-   -   Y on a battery (https://www.rcuniverse.com/forum/rc-radios-transmitters-receivers-servos-gyros-157/10658791-y-battery.html)
telejojo 08-06-2011 05:35 PM
Y on a battery
Can you use a y on a channel with a bat. and another function.I have run out of channels and need a slot for battery and ign. cut off switch and was thinking about using a y all I need for the ign. is a signal wire and a hot wire for the bat.
A.T. 08-06-2011 05:42 PM
RE: Y on a battery
ORIGINAL: telejojo Can you use a y on a channel with a bat. and another function.I have run out of channels and need a slot for battery and ign. cut off switch and was thinking about using a y all I need for the ign. is a signal wire and a hot wire for the bat.
Yes, examples:
Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid Brownout &amp; Add Redundancy, <font size="1">even one for each servo.</font>
<dt>Separate Battery for Retract Servo - DIY harness. 01 </dt><dt>Separate Battery for Retract Servo - DIY harness. 02
Alan T.
Alan's Hobby, Model &amp; RC FAQ Web Links
<span style="font-size: smaller">(quick search = Ctrl+F)
</span>
</dt>
BuschBarber 08-06-2011 06:16 PM
RE: Y on a battery
ORIGINAL: telejojo
Yes you can. For most all receivers, the Rx battery can be plugged into the Bat port or any other Servo port, using a Y Harness, where the Battery is plugged into one side of the Y and the Servo is plugged into the other side of the Y. Some people use more than one Rx battery, for Redundancy. They plug one battery into the Bat port and one battery into any Servo port. Do not plug both batteries, if you use two, into the same Y Harness.
Rodney 08-07-2011 04:45 AM
RE: Y on a battery
Yes, but be sure to use a Y with heavy duty leads. Many Y's are to puny and will cause a voltage drop just when you need the high currents.
BuschBarber 08-07-2011 05:08 AM
RE: Y on a battery
ORIGINAL: Rodney
Absolutely!!
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
