What is everyone using for a spare battery for a JR 12X?
Looking to pick up a spare battery for my 12X and wondering if anyone came up with an after-market or an alternative unit.
Thanks, Peter |
RE: What is everyone using for a spare battery for a JR 12X?
Replaced my stock 12X battery with Eneloops from Chad at Sin City Jets. I know a lot of others have done it also. BVM also sells them.
http://sincityjets.com/store-batteries.htm No special charger is needed. Charge on NiMH setting at 300 mah. With the Eneloops you will not need a extra pack you can fly all weekend and won't have to charge. If you want an extra pack, as far as I know the only place to get one is from Horizon.. Checked Horizon site and the battery is $83. |
+1 on the Eneloops and you can also get 'em at NoBS, but as noted getting an extra cassette is the big issue. A 10X cassette will fit if you can find one and they fit just a tad tighter which eliminates the concern about the pack slipping off the connector pins as noted in the SB on the radio.
Also, with Sin City you can send him you 10 or 12X cassette and he will install the Eneloops for you. No extra charge.
Horizon will not sell you just the cassette without the battery. |
ORIGINAL: bcovish Also, with Sin City you can send him you 10 or 12X cassette and he will install the Eneloops for you. No extra charge. Horizon will not sell you just the cassette without the battery. Not sure if he's just getting more involved with the jets or his real job, but I've been disappointed with my interactions with Sin City of late and keep hearing similar things from guys I've sent over there over the last couple of years..... [:o] |
Thanks for the input guys! I ended up buying a new battery pack from a hobby store on E-Bay for a spare. I'm going to send my original pack out to NoBS and have them solder in a new set of Eneloops for longer flight times, then use this new pack for back up while at the field.
Thanks again, Peter |
I did the Eneloops thing also and couldn't be happier. Great batteries and run a LOOOOOONNNNG time.
