Polk Tracker III Transmitter
Does anyone know of a way to increase the pulse width on the channel 5 (Landing Gear) of a Polk Tracker III transmitter ??
RE: Polk Tracker III Transmitter
Why do you wish to increase the width?
I have 2 trackers and never needed to change the pulse. You can play with the EPA and trims. Larry |
Larry,
One of the electric servoless retract gear sets I bought had the switch points set at the extreme range. The pulse width on the gear switch of my Tracker only went from about 1.10 to 1.90 ms. I could get some of the gears to work but only by using the end point adjustments and the sub-trim. I did'nt feel it was a reliable way to do it. |
Well, you could make a ckt that when it see's a pulse input it sends a pulse out set at your width. Something along the line of 555 pulse generator ckt that you could adjust the output pulse.
It's been some time since I designed and played with ic chips. Larry |
Larry,
There are pulse extenders that you can by to increase the pulse width. I've bought a couple. But I still think there ought to be a way to do it internally to the TX. The nominal pulse width should be 1.00 to 2.00 Ms, with the EPA able to adjust the pulse width to 0.090 to 2.10. |
Well, I would advise you to call polk hobbies.
Press the extension for sales and talk to John Gills. If there is a way he will know. Larry |
Are you really sure you need to adjust the pulse width? I would think it's a similar issue like on a JR radio where you need to adjust the end point travel to max it out like when using retract servos. Futaba retract channel is maxed at something like 134% where JR is only 100%. The servo doesn't respond until you adjust the end points to about 125% on the retract channel then it works. Did you try that?
ORIGINAL: John Sohm Are you really sure you need to adjust the pulse width? I would think it's a similar issue like on a JR radio where you need to adjust the end point travel to max it out like when using retract servos. Futaba retract channel is maxed at something like 134% where JR is only 100%. The servo doesn't respond until you adjust the end points to about 125% on the retract channel then it works. Did you try that? |
