JR12X Changing Switch Assignments
I would like to have all my radios the same on switch assignments, timer, elevator, aileron, rudder ect so they all have the same basic feel. My new JR12X won’t let me assign the 3 position rudder switch to the Flap switch on the front of the radio. Is that correct? The manual leaves a lot to be desired in that area. Any and all help is greatly appreciated.
RE: JR12X Changing Switch Assignments
Ever done any JR programming before?
I ask because I had issues with switch assignment when I moved to JR from another brand. JR isn't as good as some other brands for this, but the 12X is d*mn close. One of the things they don't seem to mention or at least I never found it, was that in order to change a switch assignment you first have to inhibit the desired switch in the setup menu, then that switch will appear as an option when trying to assign something else. There are still a few things it won't let you do, but not many.... ;) |
First JR and I like the feel but not much else so far. So is that a I think I can response Zeeb? I tried to inhibit both original flap and rudder but maybe I got it wrong.
ORIGINAL: Zeeb Ever done any JR programming before? I ask because I had issues with switch assignment when I moved to JR from another brand. JR isn't as good as some other brands for this, but the 12X is d*mn close. One of the things they don't seem to mention or at least I never found it, was that in order to change a switch assignment you first have to inhibit the desired switch in the setup menu, then that switch will appear as an option when trying to assign something else. There are still a few things it won't let you do, but not many.... ;) |
The 12X switch assignability is limited. As far as I can see there is none for the rate switches. If it is really important, you might contact Horizon and see if they can relocate it for you.</p> Allan</p> |
ORIGINAL: TOFAST4U2C First JR and I like the feel but not much else so far. So is that a I think I can response Zeeb? I tried to inhibit both original flap and rudder but maybe I got it wrong. Even as big as the manuals are for the 12X, there's just not any way to cover everything it'll do so asking questions as you've done here is a good start but you also have to be willing to play with the radio. Fortunately it's got LOTS of memory slots as well as computer backup so what I suggest is that when you get something working, back up the model to an empty slot. Then when you start messing around with the settings, you don't lose everything if you make a mistake. I do this right from the start when assembling a model and I replace the backup everytime I make a change that works. It's saved my "bacon" more than once.... lol Don't be afraid to play with the thing, you'll learn a lot and once you start to figure out how JR does things, it's actually a much more intuitive process than what I was used to with the other brand radios and it caused me some frustration similar to what you're experiencing now. |
Thanks Zeeb
I been working hard to find a fix but it looks like you cant do it. So it seems like putting triple rates for all surfaces on the Aux 2 switch will work and I will try to put the optical kill on the rudder switch. I usually like to keep my elevator separate on my birds so I dont know how I will like it. I have a 103" Extra with a DA120 to maiden and I dont want to put that high dollar bird in over poor radio settings. I eventually will get the hang of it. It only took me a year to figure out the Futaba 9C. Thanks for the tip on making copys. Keep the info coming I have a long way to go. |
Ummm.... You're not going to be able to split out a single control like your elevator while the rudder/ailerons run together and get triple rates. One of the things the JR won't do that the Futaba will since the JR doesn't have native triple rate programming. The only way to ge triple rates with the JR is to use the Flight Modes and that won't let you isolate one control surface on another switch.
Took me a bit to learn the 9C and I hated the elevator lag issue so I went to a 9Z WCII. You 'wanna talk about a tx that's tough to learn the programming... after three days and no triple rates I was ready to send it back to Tower... lol I did eventually figure it out and that's a great radio but not user friendly so when I switched to JR/Spektrum, I thought I could figure it out in a day or two; not so. I've spent a lot of time over on FG where some real sharp guys were really helping folks out with programming questions on the 12X. I've had mine three years now and I'm still learning new things it'll do which I've not seen documented any where before. It's a great radio but as we mentioned, it doesn't quite have the switch assignment versatility you get with Futaba. Oh, you're 'gonna LOVE that 120. I have one on the 2.6 Comp-Arf in my avatar and at 28.0lbs the DA hauls that thing around like a foamie. Be prepared to do some experimenting with props. |
